Hello,
Not too sharp with this, so please bear with me a bit.
Have the app up and running on W10 pc.
Everything seems to be fine, all adjustment
look “real,” etc.
But, as best I can determine, none of the setting seems to make the
slightest difference in the final sound I hear,
Is there some other connection or option to be selected or changed in the pc perhaps ?
What should I check ?
Any and all thoughts would be most appreciated.
Thanks,
Bob
Hello Bob/Robert,
Welcome to the forum.
The first thing I usually recommend is using specialized full uninstaller software to completely uninstall the program, and then reinstall it afterwards.
By the way, don’t waste money on that, there are plenty of free full uninstallers available.
Also, make sure that, upon the fresh install, you install the latest version, and also, make sure to disable all playback devices you are not using in your Windows sound settings, including the hidden ones.
So I would recommend you do that first, and then report back here with the results.
And if you still hear no difference, I will call in some assistance.
Here to help,
doolhoofd
Hi
Much thanks.
Will play with it some more, and
evaluate problem further.
Thanks for help.
Regards,
Bob
