Significant latency with bluetooth headphones?
I noticed this specifically while gaming because even just a few milliseconds delay makes a huge difference in competitive multiplayer. I did some testing with several different headsets and for all of them there was a 400-600ms longer delay when FxSound was running compared to when the program was closed.
The delay even persisted when the effects were powered off… it was only when I completely exited the program and switched the input from FxSound to the headphones directly that it went away.
Any ideas how to minimize or stop this from happening?
Hiya Red,
Welcome to the forum.
I’m not part of FxSound’s programming team, so I won’t be able to codefix your problem, and sadly I also have absolutely no idea how to minimize the lag.
But what I can tell you is that to me it seems only logical you’re experiencing delay, since you’re running your entire audio signal through an additional processing program.
Regards,
doolhoofd
