I’d like to use CTRL-SHFT-A and Z to cycle through preset sounds, but I only use 5 or 6 of the sounds so it’s a bit of a pain to have to cycle through every sound and makes me skip out on using the feature. Is there any way to select a smaller list of preset sounds to cycle through?
Related - Is there any way to get the notification for preset sounds to cycle faster? Currently it takes a couple of seconds for the notification for each preset sound to appear/go away/move on to the next. So, if I’m cycling through five presets, it would take ten+ seconds to show me if it’s on the preset I want. Is there any way to change this to instant notifications so that it shows the new preset as soon as I hit the next key combo?
