Hello. It happens to me that since I installed version 1.1.19.0 in windows 11 pro. When I disconnect and connect my Bluetooth headphones, the FxSound app does not detect them. The windows system does detect them and recognize them as active audio and microphone devices. The solution I found is to close FXSound and open it, in that step if it detects it. Clarify that version 1.1.18.0 did not have this problem. Any clean solution? Greetings.
Good evening.
We get reports of problems with Bluetooth quite often, just type the term into the search field at the top right if you want a list.
For example, this one was posted just a week ago:
Regret to inform you, I have no clean solution…
My apologies.
