I use fxSound and it’s a perfect thing, thanks for it.
The only thing is that the number of presets is very limited for comparison and testing of settings or in geniral.
If there was a possibility to create an infinite number of presets like in Realtek Audio Console it would be more than perfect.
FxSound supports up to 20 additional Presets, but can even go up to 99, if you:
Navigate to
C: \ Users \ [YourUsername] \ AppData \ Roaming \ FxSound
Find the file named FxSound.settings
Open it with WordPad, and
Edit the line, and more precisely the number at the end of this line, correctly:
< VALUE name=“max_user_presets” val=“20”/>
Note: you’ll need to go to Tools > Folder Options > View in the menu bar on top and enable Show hidden files, folders, and drives first, in order to be able to access the hidden AppData folder.
