So uh, while using FxSound my pc crashes for no reason, my pc isnt overheated, etc.
It just randomly automaticly restarts it without anything popping out, no bluescreen, no anything. I could use some help ??
Hello Moka,
Welcome to the forum.
There’s not much anyone can do from such a long distance with so little information…
But let me call in the expert anyway.
@bvijay: Any troubleshooting tips for this user?
To see if this is connected to FxSound (which it most likely not, but any driver could theoretically crash a system), just disable it and see if it still happens. If yes, it is not related to FxSound being disabled then (or even completely uninstall it).
At least we need MUCH more details on your situation!
Look for errors in the Windows system log (Event Viewer) regarding the time of the crash.
Examples:
https://docs.microsoft.com/nb-no/windows-hardware/drivers/kernel/logging-errors
https://docs.microsoft.com/en-us/previous-versions/windows/desktop/bb226812%28v=vs.85%29
etc.
See the availability of details and let know if there is anything useful.
Extremely helpful as always! Thanks, Dolmatov! ![]()
Pc doesnt crash when FxSound is disabled, it only happens when its turned on
Uh, would DxDiag be useful?
Since Event Viewer only says that The system was rebooted without a clean shutdown first. Possible causes of the error: The system has stopped responding or has crashed, or there has been an unexpected loss of power. - Kernel-Power
and thats all
SO uh
I reinstalled system to 0 and everything is working perfectly now
I guess I had corrupted files
Great! Good going. Glad it’s solved! ![]()
