Hello ,
I have an issue with fxsound my output is never saved . Even by changing the source , after computer is restarted the output is always reseted to AI Noise Cancelling. In the settings, the preferred output is not saved.
Thanks for your help
Hello ,
Okay so when you go to change your output in another device in FxSound, FxSound automatically reverts it back to “AI Noise Cancelling”?
Hi James
Yes it does ., most of the time I lose the sound and especially when restarting the pc .
Sorry about this. Is “AI Noise Cancelling” a device that you’re using? This isn’t a perfect solution, but you could try disabling as a device in Windows if you’re not using it.
