Good afternoon Estimated colleagues
I share the information of the log requested by the partner “Bvijay”
When the installation is carried out, FXSound’s virtual component is not installed in Device Manager and neither Fxsound Speaker is not present in panel control-> Sounds
In the log history it is possible to see that I have reinstated it several times but continues to present error
I am attentive to your support, thank you
[Device Install Log]
OS Version = 10.0.19045
Service Pack = 0.0
Suite = 0x0100
ProductType = 1
Architecture = amd64
[BeginLog]
[Boot Session: 2022/12/07 16:15:02.500]
[Delete Device - SWD\ASWWIREGUARD{41766173-7453-6F66-7477-617265415357}]
Section start 2022/12/07 16:27:50.246
cmd: “C:\Program Files\Avast Software\SecureLine VPN\WireGuard\wireguardtun.exe” connect -endpoint_ip 5.62.49.18 -endpoint_port 41194 -endpoint_pub_key ucSeTYidvNfjj5QspnjZNlUdXJlfiKYws2C2fTub0Gk= -allowed_ips “0.0.0.0/0, ::/0” -keepalive 90 -iface_priv_key “C:\ProgramData\Avast Software\SecureLine VPN\SecureLine\auth.wireguard” -iface_addr 100.126.10.30/32 -adapter_name “SecureLine WireGuard” -adapter_desc “Avast SecureLine WireGuard Adapter” -dns 100.126.0.1 -shutdown_event “Global\AvastVpnShutdownEvent”
<<< Section end 2022/12/07 16:27:50.252
<<< [Exit status: SUCCESS]
Section start 2022/12/07 16:27:58.012
! dvi: Query-and-Remove failed: 0x05: CR_INVALID_DEVNODE.
<<< Section end 2022/12/07 16:27:58.059
[Device Install (UpdateDriverForPlugAndPlayDevices) - Root\FXVAD]
Section start 2022/12/07 16:28:37.991
cmd: “C:\Program Files\FxSound LLC\FxSound\Drivers\win10\x64\fxdevcon64.exe” install “C:\Program Files\FxSound LLC\FxSound\Drivers\win10\x64\fxvad.inf”
ndv: INF path: C:\Program Files\FxSound LLC\FxSound\Drivers\win10\x64\fxvad.inf
ndv: Install flags: 0x00000001
ndv: {Update Device Driver - ROOT\MEDIA\0000}
ndv: Search options: 0x00000080
ndv: Searching single INF ‘C:\Program Files\FxSound LLC\FxSound\Drivers\win10\x64\fxvad.inf’
dvi: {Build Driver List} 16:28:37.991
dvi: Searching for hardware ID(s):
dvi: root\fxvad
dvi: Created Driver Node:
dvi: HardwareID - Root\FXVAD
dvi: InfName - c:\program files\fxsound llc\fxsound\drivers\win10\x64\fxvad.inf
dvi: DevDesc - FxSound Audio Enhancer
dvi: Section - DFX_Device.NT
dvi: Rank - 0x00ff0000
dvi: Signer Score - WHQL
dvi: DrvDate - 03/17/2021
dvi: Version - 14.1.0.0
dvi: {Build Driver List - exit(0x00000000)} 16:28:37.991
dvi: {DIF_SELECTBESTCOMPATDRV} 16:28:37.991
dvi: Default installer: Enter 16:28:38.007
dvi: {Select Best Driver}
dvi: Class GUID of device changed to: {4d36e96c-e325-11ce-bfc1-08002be10318}.
dvi: Selected Driver:
dvi: Description - FxSound Audio Enhancer
dvi: InfFile - c:\program files\fxsound llc\fxsound\drivers\win10\x64\fxvad.inf
dvi: {Select Best Driver - exit(0x00000000)}
dvi: Default installer: Exit
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 16:28:38.007
ndv: Force Installing Driver:
ndv: Inf Name - fxvad.inf
ndv: Driver Date - 03/17/2021
ndv: Driver Version - 14.1.0.0
ndv: Driver package ‘C:\Windows\System32\DriverStore\FileRepository\fxvad.inf_amd64_a75d87b3871a94a9\fxvad.inf’ is already imported.
sto: {Setup Import Driver Package: c:\program files\fxsound llc\fxsound\drivers\win10\x64\fxvad.inf} 16:28:38.007
sto: Driver package already imported as ‘oem22.inf’.
sto: {Setup Import Driver Package - exit (0x00000000)} 16:28:38.007
dvi: root\fxvad
ump: {Plug and Play Service: Device Install for ROOT\MEDIA\0000}
!!! dvi: Specified driver path ‘C:\Windows\INF\oem22.inf’ is invalid. Err = 0x00000002
ump: {Plug and Play Service: Device Install exit(00000002)}
!!! ndv: Device install failed for device.
!!! ndv: Error 2: The system cannot find the file specified.
ndv: Installing NULL driver.
! dvi: Installing NULL driver!
dvi: {Core Device Install} 16:28:38.085
dvi: {Configure Device - ROOT\MEDIA\0000} 16:28:38.085
dvi: Device Status: 0x01802001
dvi: Parent Device: HTREE\ROOT\0
dvi: Install Device: Configuring device. 16:28:38.085
dvi: Configuration: null
dvi: Install Device: Configuring device completed. 16:28:38.085
dvi: Device Status: 0x01802401 [0x1c - 0xc0000490]
dvi: Install Device: Starting device ‘ROOT\MEDIA\0000’. 16:28:38.085
dvi: Install Device: Starting device completed. 16:28:38.085
! dvi: Device not started (unknown reason): Device has no problem.
dvi: {Configure Device - exit(0x00000000)} 16:28:38.085
dvi: {Core Device Install - exit(0x00000000)} 16:28:38.085
ump: {Plug and Play Service: Device Install exit(00000000)}
ndv: {Update Device Driver - exit(00000002)}
!!! ndv: Failed to install device instance ‘ROOT\MEDIA\0000’. Error = 0x00000002
<<< Section end 2022/12/07 16:28:38.085
<<< [Exit status: FAILURE(0x00000002)]
[Delete Device - ROOT\MEDIA\0000]
Section start 2022/12/07 16:28:51.466
cmd: “C:\Program Files\FxSound LLC\FxSound\Drivers\win10\x64\fxdevcon64.exe” remove
dvi: Query-and-Remove succeeded
<<< Section end 2022/12/07 16:28:51.466
Section start 2022/12/07 16:29:01.170
dvi: {Build Driver List} 16:29:01.190
dvi: root\fxvad
dvi: {Build Driver List - exit(0x00000000)} 16:29:01.190
dvi: {DIF_SELECTBESTCOMPATDRV} 16:29:01.190
dvi: Default installer: Enter 16:29:01.190
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 16:29:01.190
sto: {Setup Import Driver Package: c:\program files\fxsound llc\fxsound\drivers\win10\x64\fxvad.inf} 16:29:01.190
sto: {Setup Import Driver Package - exit (0x00000000)} 16:29:01.200
dvi: root\fxvad
dvi: {Core Device Install} 16:29:01.220
dvi: {Configure Device - ROOT\MEDIA\0000} 16:29:01.220
dvi: Install Device: Configuring device. 16:29:01.220
dvi: Install Device: Configuring device completed. 16:29:01.220
dvi: Install Device: Starting device ‘ROOT\MEDIA\0000’. 16:29:01.220
dvi: Install Device: Starting device completed. 16:29:01.240
dvi: {Configure Device - exit(0x00000000)} 16:29:01.240
dvi: {Core Device Install - exit(0x00000000)} 16:29:01.240
<<< Section end 2022/12/07 16:29:01.240
Section start 2022/12/07 16:29:12.338
<<< Section end 2022/12/07 16:29:12.338
Section start 2022/12/07 16:29:21.856
dvi: {Build Driver List} 16:29:21.871
dvi: root\fxvad
dvi: {Build Driver List - exit(0x00000000)} 16:29:21.871
dvi: {DIF_SELECTBESTCOMPATDRV} 16:29:21.871
dvi: Default installer: Enter 16:29:21.871
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 16:29:21.871
sto: {Setup Import Driver Package: c:\program files\fxsound llc\fxsound\drivers\win10\x64\fxvad.inf} 16:29:21.871
sto: {Setup Import Driver Package - exit (0x00000000)} 16:29:21.887
dvi: root\fxvad
dvi: {Core Device Install} 16:29:21.903
dvi: {Configure Device - ROOT\MEDIA\0000} 16:29:21.903
dvi: Install Device: Configuring device. 16:29:21.903
dvi: Install Device: Configuring device completed. 16:29:21.903
dvi: Install Device: Starting device ‘ROOT\MEDIA\0000’. 16:29:21.903
dvi: Install Device: Starting device completed. 16:29:21.918
dvi: {Configure Device - exit(0x00000000)} 16:29:21.918
dvi: {Core Device Install - exit(0x00000000)} 16:29:21.918
<<< Section end 2022/12/07 16:29:21.918
Section start 2022/12/07 16:34:51.439
<<< Section end 2022/12/07 16:34:51.439
Section start 2022/12/07 16:35:02.063
dvi: {Build Driver List} 16:35:02.079
dvi: root\fxvad
dvi: {Build Driver List - exit(0x00000000)} 16:35:02.079
dvi: {DIF_SELECTBESTCOMPATDRV} 16:35:02.079
dvi: Default installer: Enter 16:35:02.079
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 16:35:02.079
sto: {Setup Import Driver Package: c:\program files\fxsound llc\fxsound\drivers\win10\x64\fxvad.inf} 16:35:02.095
sto: {Setup Import Driver Package - exit (0x00000000)} 16:35:02.095
dvi: root\fxvad
dvi: {Core Device Install} 16:35:02.142
dvi: {Configure Device - ROOT\MEDIA\0000} 16:35:02.142
dvi: Install Device: Configuring device. 16:35:02.142
dvi: Install Device: Configuring device completed. 16:35:02.142
dvi: Install Device: Starting device ‘ROOT\MEDIA\0000’. 16:35:02.142
dvi: Install Device: Starting device completed. 16:35:02.142
dvi: {Configure Device - exit(0x00000000)} 16:35:02.142
dvi: {Core Device Install - exit(0x00000000)} 16:35:02.142
<<< Section end 2022/12/07 16:35:02.157
Section start 2022/12/07 16:37:09.255
<<< Section end 2022/12/07 16:37:09.255
Section start 2022/12/07 16:37:19.740
dvi: {Build Driver List} 16:37:19.755
dvi: root\fxvad
dvi: {Build Driver List - exit(0x00000000)} 16:37:19.755
dvi: {DIF_SELECTBESTCOMPATDRV} 16:37:19.755
dvi: Default installer: Enter 16:37:19.755
dvi: {DIF_SELECTBESTCOMPATDRV - exit(0x00000000)} 16:37:19.755
sto: {Setup Import Driver Package: c:\program files\fxsound llc\fxsound\drivers\win10\x64\fxvad.inf} 16:37:19.755
sto: {Setup Import Driver Package - exit (0x00000000)} 16:37:19.771
dvi: root\fxvad
dvi: {Core Device Install} 16:37:19.786
dvi: {Configure Device - ROOT\MEDIA\0000} 16:37:19.786
dvi: Install Device: Configuring device. 16:37:19.786
dvi: Install Device: Configuring device completed. 16:37:19.786
dvi: Install Device: Starting device ‘ROOT\MEDIA\0000’. 16:37:19.786
dvi: Install Device: Starting device completed. 16:37:19.802
dvi: {Configure Device - exit(0x00000000)} 16:37:19.802
dvi: {Core Device Install - exit(0x00000000)} 16:37:19.802
<<< Section end 2022/12/07 16:37:19.802
