Old Issue: FxSound creates startup shortcut pointing to Program Files (x86) directory. I thought this was fixed quite some time ago, but it seems to have appeared again.
Current release does not install anything to that directory. Old issue may be old setup.exe?
Don’t think so, but anything’s possible.
*though this needs extra info, screenshorts or recording, with your fxsounds setups and logs and your pc setup bc there's nearly zero information at all to begin with.*
I’m quite confused, as far as I understand the seperate x86 files are for supporting backward compatibility for 32 bits, regardless of fxsound does or does not make a shortcut there, could you explain the issue here? (e.g are you having trouble starting up fxsound or needing help with making a convenient shortcut on desktop or task bar or start menu?)
