Startup lnk created is for the wrong folder
On my system, the Startup lnk created points to Program files (x86) for the FXsound folder, but on my system it’s in the Programs Files directory. I have installed the program several times and the results are always the same. Is this a bug, or just a fluke on my system? Thanks!
That’s a bug. Do you have fresh msi*.log files in your %temp% folder?
Here’s a screenshot showing where the startup lnk is created:
Here are some msi files:
I performed an uninstall of the program, and made sure there were no directories left. Then I installed the program. The FXsound LLC directory was created in the Program Files directory,
not the Program Files (x86) directory.
Thanks for your help.
(Attachment File Missed error 8-21-2024 7-11-35 PM.pdf is missing)
(Attachment MSI54d34.LOG is missing)
(Attachment MSI240ee.LOG is missing)
(Attachment MSI468D.LOG is missing)
(attachments)
File Missed error 8-21-2024 7-11-35 PM.pdf.txt (9.96 KB)
MSI54d34.LOG.txt (294 KB)
MSI (s) (38:08) [19:02:29:713]: PROPERTY CHANGE: Adding DFX_UNINSTALL property. Its value is ‘C:\Program Files (x86)\DFX\uninstall.exe’.
Do you have installed DFX ?
Yes.I may have sent the wrong msi file. Your email system only accepts 2 files. But, doesn’t that show you that the install/uninstall is working with the wrong folder?
Here’s two other msi files. Sorry for the delay.
(attachments)
MSI240ee.LOG.txt (239 KB)
MSI468D.LOG.txt (31.5 KB)
