new version no work in w7 64 bits ![]()
That’s strange, because I run Win7 x64, and I have no issues.
I already installed it again, changed the compatibility and nothing solved
Can you try installing Visual C++ redistributable from https://aka.ms/vs/17/release/vc_redist.x64.exe and then install FxSound
still the same problem ![]()
If it really does not work, maybe you can give the old version a try.
If I understand correctly, it’s free now as well.
I went back to the old version 13.028. it’s working fine as before ![]()
