I did all the steps, it doesn’t appear as a driver or as disabled, I uninstall it and install it still doesn’t appear
Hi Pedro,
I sent @bvijay a message to notify him of your problem.
Could you please also check the two folders described here?
Also: have you checked the Programs section of your Control Panel, and did you get any error pop-ups after running the installer?
I completely uninstalled it and it really worked, both the driver using the driver store explorer and doing this method, thank you very much
