i have install the new version of fx sound but its not showing in the sound setting i try reinstall in many time but still have the same problem anyone can help me with this ???
This is just a wild guess, but have you tried right-clicking in the areas of your sound devices and selecting “Show hidden devices?”
i tried but nothing popup on that screen
Okay.
I’m sorry, I really don’t know a way to fix your problem.
There were known problems about this with Windows 10 Update (see Method 3).
Method 1:
Start → Run → mmsys.cpl
Enable ‘Disabled’ items e.g. FXSound
Method 2:
Uninstall the sound drivers via the Device Manager (without deletion of drivers files).
Windows will redetect the sound drivers and enable the missing devices…
Method 3:
Run the Command prompt as Administrator.
net localgroup Administrators /add networkservice
net localgroup Administrators /add localservice
exit
Reboot
