I am not able to select my Jabra headset when Music FX in open
I have tien a lot ot times to make it work the only way it is to end the process but I cannot enjoy the sund effects,at all.
Can you please confirm if the Jabra headset is single channel mono or stereo?
It’s a Jabra Link 230
In summary, the adapter is versatile
Dual MONO/STEREO
FxSound sometimes doesn’t detect certain USB adapters immediately. For your Jabra Link 230:
  1. Make sure the headset is set to Stereo mode in the Jabra software.
  2. Restart FxSound after the headset is connected.
  3. If it still doesn’t appear, try unplugging the adapter, reconnecting it to a different USB port, and reopening FxSound.
This usually allows Music FX to recognize the headset properly.
