I can’t access setting, FxSound is running but right click on Icon opens windows settings options only.
Is there some magic trick Im missing?
Which version of Windows & FxSound do you use?
Good afternoon Greg,
It’s the “hamburger” icon, the three small horizontal lines, located in the top right corner of the interface, where you need to click on “Settings” when the menu opens. ![]()
Inside the Settings, there are two tabs, General and Help:
FxSound 1.1.27.0
Windows 10 Pro Ver. 22H2
Thanks,
Gregg
FxSound 1.1.27.0
The only way I can access this panel is:
Start
FxSound/Right click/more/Run as Administrator
Yes Allow for App to make changes to your device.
That opens the FxSound Settings window
I have tried in the app to the task bar but that doesn’t work
i can’t right click on Fx Icon, this only provides windows sound settings. The Fx Icon shows briefly in hidden icons but disappears immediately
Thanks,
Gregg
Your account don’t have admin rights?
Not sure I understand, Its a personal laptop.
Maybe you could point me in the right direction to fix this?
Thanks,
Gregg
