Hello everyone, I have a question.
I’m using a laptop, and in the past, when I remove the earphone to line while the speaker mode is mute, it automatically switches to speaker mode and mute is maintained.
It doesn’t work with fxsound on. Is there a way?
Hi DZ,
I don’t know if I’m understanding the problem correctly, but either way, could you please first try both options for automatic output device switching in the General tab of the Settings, and post back to let me know if that helped?
I solve this problem. thx for your advice.
i leave other reference solution
https://blog.naver.com/theamjay/221801367680
Glad to hear that.
Thanks for sharing the solution.
