FxSound prevents PC from going into sleep
When FxSound works and it uses my headphones, it doesn’t let the PC go into sleep mode, the monitor turns off for 1 second and comes back. Help please
erm did you click the sleep button on your pc? but i’m curious were you away and something was still playing cuz how did you nail down the cause to one
? :eyes:
I have had this problem since a couple of versions ago. The thing is that it prevents the PC from going into sleep regardless of the specific output. “powerconf /requests” shows that the legacy kernel driver is active and overrides the sleep setting, but I haven’t been able to find any more detail about it. I have tried several other Eq software, but FxSound is the only one that has this type of behavior.
