Hi. Can I somehow disable notification during every restart. Thanks.
The developer suggests turning off notifications in Windows settings.
Please confirm if it helps or not. You may need to wait for the next version.
Win 10 x64 22H2. All notifications is turned off but this one keeps coming up.
Hi corttex,
I wouldn’t call this a “known issue,” since it’s normal for these notifications to appear…
But I can understand why some users might want to disable them.
As Vijay mentioned in the thread linked above by @Dolmatov, an option to disable these notifications is something that will probably be added in future versions:
It has been a year and this problem is still not solved. Please fix it. Thank you
Vijay informed me yesterday that he fixed this issue on Win10.
But it has not been fixed for me, I have version 1.1.20.0, do you mean that it will be fixed in the next update?
Yes; the fix still needs to be integrated into the next release together with the other updates.
Apologies for the misunderstanding.
