FxSound not working ONLY with my headphones
FxSound is not working with my headphones output device which is razer black shark v2x(audio jack version). When I first got the headphones It worked for a day or so n thn it started to bug out and etc etc until it doesnt output the audio even tho fxsound is saying tht its taking in audio n changing the audio but it j wont output the audio to me.
WHat can I possibly do??
(I tried reinstalling n all tht stuff)
(For more information lmk)
It sounds like FxSound isn’t sending audio to your Razer BlackShark V2X headphones. Make sure the headphones are set as the default playback device in Windows, then restart FxSound. If that doesn’t work, try updating the headphone drivers and check if FxSound is set to the correct output device. Using the audio jack sometimes conflicts with virtual audio routing, so testing with USB headphones or another output can help isolate the issue.
It is the default output device in windows. It was working fine with Samsung wired earphones (Audio Jack). It aint working only with headphones for sum reason. (BTW am doing everything correctly like literally)
