FXSound doesn't work with AIMP3
Hi! I find FXSound very useful and it works 110% correctly.
I only have one problem: when I run AIMP3, FXSound doesn’t detect it and doesn’t boost the sound volume. In the settings, there’s no option to “include” AIMP3 for detection.
Any suggestions or help?
Thank you very much.
Best regards.
David
Hi @DavidNK,
I tried playing MP3 on AIMP3 app and FxSound is able to boost the volume of the audio playback. If FxSound is running and FxSound Speakers is the default audio playback device then audio gets boosted regardless of which application is playing audio.
Can you please share some details on the AIMP3 application scenario which is not working for you.
Hi @DavidNK
FxSound and AIMP work fine on my system. It would be helpful if you could provide more details about your setup.
Try configuring AIMP as follows:
