FxSound Crashing after RDP remote access. It is not able to handle remote audio device.
Hi @bvijay, I just donated again. My workaround is to set RDP audio to “Play on Remote computer” where FxSound is running. I would still like to hear the audio on the client during the RDP session, but “Play on this computer” is still not working with the latest release.
I wonder if you could program FxSound to exit/disable itself by detecting the RDP session and then restarting/enabling when the RDP session ends?
Hi @jngerber,
Thank you for the support and encouragement through your donations.
I appreciate your suggestion on handling RDP scenario. I will analyze the feasibility on detecting RDP session from the application and keep you posted on this feature implementation.
Thanks @bvijay.
