Hello good morning, when I use the Windows 10 remote desktop, this error is very annoying, I would like to solve it please.
Sorry about this. Do you have the latest version? And are you using audio while running remote desktop?
Good night if I have the last version of FXSound 1.1.31.0 so the error appears every time I start remote session on the computer I control.
It has been happening years to report it. Please fix it.
The problem only appears when the remote desktop mode is used when the computer is being used normally without using the remote desktop does not fail, it fails when session is started in the remote desktop mode FXSound is deactivated and the error appears.
Hi @josebraund
Please refer the remote desktop audio behaviour that I had explained in a different thread earlier. In remote desktop connection, if you choose play audio on local computer then FxSound Audio Enhancer device will not be available and FxSound cannot run.
