tymes
December 9, 2022, 4:35pm
#1
[image removed]
Minor, but can we avoid this? I connect remotely via RDP but I don’t… wait, I thought I didn’t send audio (aka no audio device and causing Fx problems), but I do… so not exactly a minor problem.
Can you fix it so if the audio is “remote audio” or if there is NO audio that Fx doesn’t have a problem?
tymes
December 9, 2022, 4:40pm
#2
Yes, also a problem if RDP with no sound…
Hi tymes,
This issue is currently being investigated in the thread linked below, so please follow the advice given, and post there as well:
Hi @Milincho ,
Yes, this is a known problem, there have indeed already been multiple reports of issues while using FxSound combined with Remote Desktop; this was the advice offered by FxSound’s lead programmer @bvijay on the difficulties with RDP:
It would help the troubleshooting effort if you could:
Try the proposed solution “Allow audio and video playback redirection,” and
Run the Powershell check,
And post back here with the results.
Also, the user who opened the thread, added this re…
