FXSound crashes my PC after about 2 minutes of use
Hello, I am trying to use your FX sound with a Razer Leviathan V2 X when I switch to it and try playing on it, it runs for about 2 minutes before freezing and then crashing my PC
Good afternoon John,
This is a quick link to my standard troubleshooting list; other than that, if you really want to use FxSound, you could perhaps try installing one of the previous versions…
But if none of those tips help, then I would suggest finding an alternative audio enhancer, since a system crash is a pretty serious event.
Here’s a short list, I’m sure there are many more:
