FxSound causing lag/skipping sound often
Every so often, i’ll get a constant audio issue where the sound is constantly skipping every half second or so. I have to completely close FxSound to get the audio working normally, or restart my computer every time. Neither is a permanent option.
I am unsure what’s causing this. In my FxSound app, i have the output audio set as FxSound, and my windows control panel speaker output is also FxSound.
Don’t know what to do to have this permanently fixed as it happens with whatever version.
Hi \2hd#Tf8)F,[ ,
Have you tried applying the suggestions from the main troubleshooting thread at the top?
I would particularly recommend scanning with LatencyMon.
Hello @Kinyelo and welcome to the forum, how much RAM do you have and how old is your PC/Laptop and what CPU do you have, i used to have the same problem a few years back with my old pc is had only 2 GB of RAM but now with my current laptop it has 12GB or RAM so no problem there, so consider the option of upgrade to more RAM or even upgrade to a new pc/laptop, and don’t forget to try out LatencyMon as @doolhoofd suggested it will give you some good results
I’ve got 32GB of ram.
That’s strange ok so ram is not an issue here, but what about drivers do you have the latest drivers installed?
Everything is updated.
To be fair, neither do we…
