In version 1.1.26.0, there is an export bug. While having a different preset loaded,
click on export preset and select the default preset. It exports it. Then open it
with editor and see it exported the loaded preset instead of the selected preset(default) in this case. I reproduced it.
Confirmed.
It retains the Default name, but imports back with the settings of the loaded one as well.
Thanks, Chris.
I tested this further.
It happens with all Presets, not only the Default one.
Forwarded.
Should be patched up in no time. ![]()
Thank you Chris for finding this bug. We will get it fixed in the next release.
You welcome. Amazing software. It gives me a never before audio experience, even tho i just listen in stereo.
Fixed, though currently still in beta:
