Effet Réverbération
Bonjour,
A chaque fois que j’actionne l’application FX Sound je m’aperçois que toute ma musique quelque qu’il soit a un effet reverb . Comment je dois faire pour ajouter du volume sans la réverb . Merci encore de votre aide
Mitchy ........hellmic@hotmail.fr
What preset and audio settings for master gain, normalization and filter Q have you applied?
  • check the ambient effects in your preset
  • check if there are any active enhancement audio like “spatial” or some boosting effects in the pc’s sound panel
  • last but not least, check your headphones if it has companion app to see if you have any “preset” on, this one stick/ engraved onto your headphones most of the time. Lots of modern headphones or earphones usually have an app regardless of cable or bluetooth.
For examples, sony headphones have a mobile app called Sound connect, Momentum 4 has Smart control plus, cabled-only AW510H has its own section in AWCC… The companion settings will consistently stay on top of all other settings of all other apps because as the name said, they’re companion.[1]
OH and if wanna trick around, clarity should “parry”/ cancel out the reverb effect to some level
  1. even if you switch devices, once something is set in these official apps, they stay ↩︎
