What's the best settings for Envolving/surrounding music?
Hello guys!, I just downloaded FxSound and I would like someone to give me “the best settings” for a surrounding music, greetings!
This seems fairly straightforward - for music, try upping the Surround Sound Effect to level 4, 5, or 6 at the highest. Pushing it beyond that usually results in overkill, and degrades the listening experience.
Anything else is basically up to you, and your personal preference!
By all means, feel free to experiment, play around, and try out different combinations, to find the settings most pleasing to your own ears.
Adding some Clarity always sounds nice; so’s a little Dynamic Boost…
The Ambience Effect adds reverb (which I personally find unnecessary when listening to music)…
This is a quick link to the biggest Preset pack shared on the forum so far…
Since v1.1.22.0, you can add up to 100 additional Presets to your menu…
All tutorials about FxSound are compiled in this post, including the instructions on how to save your own custom-made Presets…
And the forum also has a dedicated thread for Preset sharing.
:butterfly:
