Echo type sound issues
Some times, suddenly i get echo type sound output when Fx sound is ON. But once i turn off Fx sound, sound output is normal. Can any one help
Do you have the Ambience and/or Surround sliders maxed out by any chance?
The Ambience slider specifically, adds what is known as “reverb” to your audio:
Hi Ambience and Sourround sound are not fully maxed, but around 70%
Those are still high settings…
Could you try turning those down, and report back to tell me if the problem persists or not?
Do you mean i should completely zero them?
Somewhere between 0 and 3, 4 max.
Try setting them like that; listen to the output to try and ascertain if this is the cause of the echoes or not; and report back here with your findings.
Those sliders are the first thing that comes to mind when hearing about the problem you described, so it seems best to try to eliminate them as a possible cause first.
