Problem is that after installation of this SW, i am required to use FxSound as it somehow modified sound properties so bad that every output is quiet like 60% lower…
That means that after uninstalling this equalizer app i can no longer listen to audio.
There is no such thing as boosting the audio so without app i hear maximum that device allows me and then with app it boost my audio… no there is no distortion of audio it is clear and normal.
Please get back to me soon and try to fix it. And as i say it was not like that.
This “boost you audio” do opposite.
Hi.
There’s a troubleshooting list bannered to the top of the forum with the most common tips.
If you want to get rid of FxSound, your best bet would be to either manually remove the FxSound Audio Enhancer driver from Device Manager, or to use specialized uninstall software like Revo Free Uninstaller; restart your computer; and perhaps roll back the driver of your main audio device to its former state - at your own risk, of course.
Copied from the FxSound licence header,
