Hi, I use FxSound on the Gaming preset (all default), I noticed that CS2 audio has become really choppy when the output device is set to the FxSounds speaker, insanely choppy, could someone check themselves to see if it happens to them? I can also make a video if needed… thanks
Hi, good evening.
You can run through this list of settings to check if FxSound is set up right and to perform some basic troubleshooting:
In the Help section of FxSound’s Settings menu, check to make sure you have the latest version installed (v1.1.20.0) available from fxsound.com or the Microsoft Store;
Make sure your computer, Windows and sound devices have received all the latest updates;
Try completely removing and then re-adding the problematic sound device(s);
Try browsing their manufacturer’s website to find and download software built specifically for your devices;
In the General section of FxSound’s Settings menu, try changing the setting for automatic switching and see if this improves anything;
In Windows Sound Settings, make sure all your devices match at the same setting, with “24 bit 48000 Hz” being the maximum supported by FxSound;
In Windows Sound Settings, make sure the FxSound device is set as the Default Device;
If this doesn’t improve anything, try setting FxSound as the Default Communications Device (this actually sets FxSound as both the Default Device ànd the Default Communications Device simultaneously, but only shows it as the Default Device);
In Windows Sound Settings, disable all Enhancements including Loudness Equalization for all devices;
In Windows Sound Settings, disable Exclusive Mode for all devices;
In Windows Sound Settings, disable Hardware Acceleration for all devices supporting this option (can usually be found in the Advanced tab);
In Windows Sound Settings, under the Communications tab, select “Do nothing” as the response to Windows detecting communication activity;
In Windows Sound Settings, disable all the devices you don’t need, including the hidden ones;
If the issue is CPU-related, then downloading LatencyMon and running a scan while FxSound is On could help you identify the cause of the issue;
FxSound’s UI graphics is built on an OpenGL-based framework, so you could check if your graphics hardware supports OpenGL and if OpenGL is enabled with DirectX Extensions Viewer;
Try downloading the program from a different source and installing that version instead (e.g. if you’ve downloaded from fxsound.com, try downloading from the Microsoft Store and vice versa);
Since the FxSound driver can be removed with relative impunity, you could try performing a manual driver uninstall;
This is a bit riskier, but you could also try increasing the priority of the FxSound process in Windows Task Manager;
Finally, you could try uninstalling with specialized full uninstaller software - this one is a last-resort option in case all else has failed.
I hope one of these tips solves your issue.
If so, please let me know.
If not, please also let me know, so we can explore further steps.
P.S.: Shoutout to @caleb59 for suggesting LatencyMon.
Thank you! But the problem is I am being double changed for “donations” because Dell sent me 4 bad pcs that had to be replaced. I am now stuck with this one. I am CELZ and Ell. Celz was my first account then due to temp pc problem I had to create the Ell account . My first account, Celz is the one I am using but donations come from Ell monthly, so how so do I let you know to stop asking for more money every single day?
Please help resolve this. Thank you!
OOPs, I was trying to reply to my other account. Sorry.
No problem.
The software is free and donations are optional, so I am surprised the program is “asking you for money.”
As I mentioned, I’ve alerted the team to further sort this out.
If you would like a refund (or multiple refunds), this shouldn’t be a problem, you can just ask James by tagging him; simply write the @ symbol and then his name.
I hope this was helpful.
