Can I enable and disable fxsound for specific apps?
Hi! Fxsound has been great however, is there a way to disable it for specific apps?
For instance, I like my music presets but only for Spotify. I don’t like those exact presets for other applications like Minecraft or Google Chrome. Sometimes I listen to music while I game but fxsound makes the games more echoey (due to my presets).
Any way to have Fxsound enabled for Spotify and disabled everywhere else?
Hi cujoh,
It’s a function that is definitely under consideration, and maybe even already in active development, for future releases, and I would advise you to add your specific desires and wishes to the existing thread on that topic, linked below:
