When disconnecting and reconnecting my Bluetooth headset, i often need to kill FXSound for my headset to play the audio it is supposed to. After killing it, it is fine if i reopen it. This bug only occurs if there is no other devices available then the Bluetooth Headset, meaning that once it is disconnected there is none at all.
Also if the setting “Automatically switch to newly connected output device” is turned on, if i reactivate another device while the sound isn’t working on my headphones, after switching back to my headphones it works. But if the setting “Automatically switch to newly connected output device” is turned off, if i reactivate a second audio device, and manually switch to it and then back to my headphones, it still doesn’t work (on both devices!)
