I’ve read a number of the posts already addressing this issue and wanted to know if anyone has a definite fix for the issue. I’m using Win 11 with Realtek Bluetooth. I just got some new buds and was able to connect them to the PC, but not use them because they just as quickly disconnected. I removed them from my Bluetooth list and have not been able to get my PC to connect them since. After checking for Bluetooth driver updates and using other suggestions from the Bluetooth manufacturer, I still can’t get them to connect. Any solutions?
I had a similar problem that comes to mind after reading your post. The solution I found by trial and error was another device was paired to my earbuds and was grabbing the priority from my TV so even when my earbuds connected to the TV it immediately disconnected because the PC took over. I have to make sure the Bluetooth is disabled first and then it connects and stays connected until I manually turn them off. Your situation sounds very similar in some aspects but with different devices. I hope this points you in a direction where you can solve it.
Thanks for your suggestion, @gsoden772 . After disabling my iPhone’s Bluetooth, I was able to get the PC to recognize and eventually connect to the earbuds. Unfortunately, that’s as far as I was able to get because, even after being shown as “connected”, I couldn’t get iTunes to play in the earbuds. Bluetooth just doesn’t play well with FxSound. I know the guys are working to correct this, so I’ll just bide my time. Thanks again!
