I know that asking about the best configuration may not be the most accurate, because from what I have researched about the sound configuration it is something extremely broad, but I would like to ask you about what you would think would be the best configuration to play this kind of game games? Considering the steps very important.
I am ignorant on the subject and I get confused when I see so many things to move in the program. Iāve already used the gaming option but I feel like itās set up in a more general sense and can be set up a bit more towards shooter games.
Hello Egan,
Welcome to the forum.
Personally, Iād recommend starting from the Gaming preset and boosting the Ambience and Surround a bit further - but FxSound is fully customizable to your own liking and taste.
You can find all the info in the Learning Center:
Hereās the tutorial on effects:
Video:
Hereās the tutorial on the Equalizer:
Video:
Once youāre done, donāt forget to name and save your preset!
Hereās the tutorial on presets:
You can tell Windows what audio device to use for the software you use to play music. Say, if you use Spotify, right click the audio icon on the toolbar tray (bottom right) and click Open Volume Mixer. The apps using sound will be listed, click Spotify and for Output Device, change it from Default to your sound device. This way, Spotify will bypass the equalizer and play directly on your sound device.
