About downloading FxSound
Why does it say ‘‘Download for Windows (Intel)’’ when I try to download FXSound?
I haven’t encountered such a message before. Is this application only compatible with Intel? Since I use AMD, will I not be able to improve the sound quality due to compatibility issues? "I’m a bit confused, I would really appreciate it if you could explain.
Intel and AMD CPU architectures are the same. The download link says Intel in short, but this version is compatible for both Intel and AMD CPU machines.
