FxSound not working MS11
Hello everyone
I have trouble installing fx sound on surface pro 11
I think that the cpu being in arm makes it difficult to install and the program is not compatible.
Any solutions? Or a forecast?
Thank you
@bvijay Is FxSound compatible on ARM devices?
No, we support only Intel 32 bit and 64 bit CPU architectures.
Hi @Azdekavir
We have added support for ARM64 you can try the beta version from https://github.com/fxsound2/fxsound-app/releases/download/beta/fxsound_setup.arm64.exe
