Processor error?
I try to install latest version 1.1.34.0 and I get an error ““This installation package is not supported by this processor”. I’m on latest Win10 64-bit 22H2 (with all updates).
I have many latest apps installed, included Photoshop and many “heavy” apps, and only this one have a "conflict"with my processor.
Btw, version 1.1.33.0 working like a charm.
We have two different installation packages for Intel/AMD CPUs and ARM64 CPUs. Ideally, the download should have automatically selected the correct installer.
But, if you are facing installation error on processor support, you can manually download the installer depending on your CPU from these links.
Intel/AMD - https://github.com/fxsound2/fxsound-app/releases/download/latest/fxsound_setup.exe
ARM64 - https://github.com/fxsound2/fxsound-app/releases/download/latest/fxsound_setup.arm64.exe
Thank you bvijay, first link Intel/AMD fix the problem. No more error :+1:
