VOLUME/AUDIO: Fx Sound is fading out any other audios when playing another sound
I kindly ask for your help!
I’ve looked all over FXSound and haven’t found any settings. I searched and redid Windows 11 settings several times, both in the FXSound audio driver and in the Windows sound driver, but nothing stopped this automatic decrease:
EXAMPLE:
If I’m listening to a video on YouTube, and a standard Windows ding rings, the YouTube video has volume 0 and the biggest problem is that it takes a while to return to normal volume. This is happening with any other sounds, for example: alarm; reminders; etc.
HOW TO CANCEL THIS FXSOUND SETTING? AS IT ONLY HAPPENS WITH IT AND NOT WITH THE WINDOWS 11 DEFAULT SOUND DRIVER.
Thank you
This behavior is caused by Windows “Communications” settings, not FxSound itself. To fix it:
  1. Right-click the speaker icon in the taskbar → Sounds → Communications tab.
  2. Select Do nothing instead of “Reduce the volume of other sounds.”
  3. Apply and restart FxSound.
This will stop Windows from automatically lowering other audio when system sounds play while using FxSound.
Já tentei isso e não funcionou!
IMPORTANT:
Uninstalling FXSound will make the problem disappear… It’s bad to be without it!
IMPORTANTE:
Ao desinstalar o FXSound o problema desaparece… Ruim é ficar sem ele!
