First time I’m hearing about this.
Let me notify @james and @bvijay for you to try and set this straight asap.
On behalf of the FxSound team, my apologies for the inconvenience.
Change a value 0 to 1 <VALUE name="survey_displayed" val="1"/>
Additionally, you can change the polling timer, or add it in the absence. <VALUE name="survey_timer" val="1648246253"/>
1648246253 = Fri Mar 25 2022 22:10:53 GMT+0000 https://www.unixtimestamp.com/
On this site it is convenient to convert the value for its viewing and reverse conversion for use.
I hope this fixes it; thanks again for the solution, Dolmatov.
If the pop-up keeps appearing, please post back here, and we’ll explore further options.
Yes , I will. I’ve made the changes to the lines suggested in the settings file. So far so good , but I’ll post back here if the survey pop-up reappears in the next few days.
BTW i wonder if there is a similar line that could be added to the settings file to suppress the splash screen(s) that always shows on startup.
Normally, after the first pop-up, application itself sets the settings “survey_displayed” to 1 to prevent the pop-up from appearing again. But, if that is not happening, it is better to check if the FxSound.settings file getting saved correctly or not due to any access rights issue or the file being read-only.
