The only thing I can suggest is a presets applied for each device separately. Now you need to switch between presets after changing an output device. It’s not the best UX.
The application is great BTW.
Hi hamsta,
Thanks for the feedback; glad you’re enjoying the software.
James already thought of adding such a function back around the end of 2021.
I’ll go ahead and add your post to the existing thread on that topic,
