when used in startup and it autoloads all the default presets are not available only the presets that you made are available. To fix this have to exit and reopen so cant use in startup
[pretend that those are the presets that i made]
First thing that comes to my mind is this reasonably simple trick:
Let me know if it works.
If not, we’ll look into other options.
should i rename the folder to something else?
Yes, I don’t think it matters all that much how you rename the folder, as long as the name is different.
I just realized, this will probably cause all your custom presets to be deleted…
what will happen if u rename the folder
FxSound will return to factory default settings…
As if it were newly installed
so what should i do?
i dont use fxsound on startup now tho
Hello Vijay,
User @Monsterblastkeythrow’s FxSound refuses to load the already-present, non-custom-made Presets upon startup.
My knowledge of the program is insufficient to address this problem, so, as usual, I’d like to call in your help.
