I have changed the Gaming preset and I can type in a preset name, but I don’t see anywhere to save and it is NOT saved. Help will be appreciated.
Sorry about that. Could you try this guide for saving presets: Saving Custom Presets (and more!) - FxSound Learning Center
If that doesn’t work let me know!
Thank you for your suggestion, but it still doesn’t work. After I name the setting and go to any other part of the screen, my name disappears and it is not saved.
Hi @veeman
When saving a new preset, after typing the preset name in the text box did you press Enter to save the preset?
Doh!!! I was looking for an “enter” button on the preset screen, it never dawned on me to use the “enter” button on my key board! Everything is fine now. Thank you very much.
