My FX sound is cutting out of nowhere
It would cut for like 1 second every 5 seconds or something, then it would work for a bit, then the cuts become worse. I tried uninstalling then reinstalling again. No work.
Sorry to hear this! Does the problem continue when FxSound is off? Or when the FxSound app is closed? Or when FxSound is uninstalled?
Nope. The issue only happens when FXSound is on. When its off or uninstalled, its fine
Hi @lawlight
Is any author audio processing application installed and enabled? Is Exclusive Mode enabled on the audio playback device and any other exclusive mode audio application running?
FxSound processes audio streams to passes it to the playback device, if any other application is in contention in processing the audio to the device then it can affect the audio output.
The only other audio output is my actual headphones and i can’t disable those because then FxSound will not have a sound output
Are you using wired headphones or bluetooth?
Can you check if you have enabled Spatial sound by any chance?
wired and no i don’t
Hello, sorry for the late response. I can send you a video of the issue through email if you want so you can see how its acting
No problem. You can upload the video to a cloud drive and provide us the link.
Did you ever find a solution to this problem? I’m facing the exact same problem right now. Uninstalling and reinstalling does not work, updating it does not work.
Correction : fxsound was in my case not the culprit
my speakers connected to DAC were setup at full volume
Actually lowering my speakers volume knob at the back of the subwoofer while keeping sliders higher soered the cutoff, or so it seems
The same thing happens to me and I identified fxSound as the culprit too, shutting it off stops the sound from cutting at lower activity in games.
