IFxsound input
Fxsound works. “but” I have a hearing problem so I have to boost the treble when I use headphones. That’s when it goes wrong. Fxsound can’t handle the input coming from e.g. windows media player. I have to turn the media player down almost completely to avoid overdriving in Fxsound. It would be good to have an option to control the input volume in Fxsound.
Probably not what you are looking for but I also have hearing loss but I don’t have your problem with Windows Media Player, mostly because I decided long ago that WMP sucks big time. I switched to VLC Media Player. Try it and see if you have the same problem.
The problem is exactly the same in VLT. I have to turn the volume down to max 70% otherwise the treble distorts.
