How to disable open on startup? It’s kinda annoying
Click on the Windows button on the bottom left of your screen, and type in “msconfig” .
This should show you the msconfig.exe file; click it.
You can select the programs you wish to run on startup there.
Alternatively, you can use (more or less free) software like CCleaner, which also offers this option.
