Disappointed in the sound on my new laptop…installed FxSound but disabled it quickly because I didn’t realize you had to note when you’re using headphones vs. external speakers…I didn’t hear anything…I may install it again, but since then I have subscribed to YouTube Premium which has helped audio quality…I wanted to do one more thing before re-installing FxSound and that is getting a new pair of headphones…I’m using a lower end Koss pair which despite the low cost I’ve always liked both for the sound and comfort…I am willing to upgrade though, for a reasonable price…any suggestions on something that’s higher quality but maybe still in a reasonable price range?..say 50-100, but closer to 50?..thanks
you always can go to store to test them and check for you budget.
good idea, though I’ve spent more than enough time in Best Buy lately through tv and laptop buying…onto smartphones next
good idea though, they would I assume let me use them on this laptop
I recently bought Anker Soundcore Q20i within this range. It supports Bluetooth and 3.5mm Aux. I am happy with its performance.
thank you…I think I need to re-install your extension and give it a better try first…my headphones are good for a low cost pair and they worked fine on my old laptop…this Lenovo, while providing good clarity, is just not producing enough volume
