All the translation strings for the languages supported now are available in GitHub repository,
Strings/Strings at main · fxsound2/Strings (github.com)
FxSound.txt is the template file which can be used to add new language translations. If you are providing us translation support in a new language, copy FxSound.txt to FxSound..txt and modify the contents with translated strings on the right.
The system has modified the file name format I had given as target file for new language translation.
Here is an example,
The new language code should be in the filename as for example if the new language is Danish, then the new file copied from FxSound.txt will be FxSound.da.txt
If we are supporting a new variant like French (Canada) then the new language is FxSound.fr-CA.txt
