FxSound starsted clipping today
I’ve been using this for over 2 years but today it started clipping the sound, it’s only when its on…
I’m also clipping.Did you solve it?
My dude, this is the sign that tells your preset setting is not cooking. you can hammer a nail to make good, but you can also hammer your finger if not careful, it’s how you use the tool.
in other words, you should try lower the gains and explore “better” [1] presets.
  1. objectively different for everyone sooo ↩︎
if i misunderstood and what you meant is the “popping”, “crackling” noises, luck is with us today because it is common, your source of media is the cause, nothing to fix here. in some cases it just bc your cable is loose or you switch between presets too suddenly and often. your gear will be fine as long as it just a pop.
@DaBigCat @imnono Can you provide some details on your audio settings in which you experience the clipping
  • Preset you are using
  • Audio settings for master gain, normalization, filter Q and balance
