Also, most web browsers have locations where you can change the permissions for access by other applications and devices.
In Chrome, the extended version of these site-specific permissions can be opened by clicking the “Site settings” cogwheel at the bottom of the window shown below, and the general version is located under:
Settings > Privacy and security > Site settings.
Thank you for trying to help but maybe i should have noted it’s not just my Browser but system sound to so if i play music through Windows Media player etc.
Thanks you but unlike that person powering of FxSound like normal worked to fix the issue but the problem for me is i want FxSound on all the time without causing these discord issues. My Headphones are to powerful for my pc normally so i need an AudioBooster to have even decent audio. What would you suggest i do and what is the person in this post suggest i to do? Thanky
I was at a friend’s house recently, and he had a miniature amplifier for exactly that purpose.
Do you connect your headphones via Bluetooth, via jack, or via USB?
There’s also a concise summary of alternatives to FxSound located at the end of the troubleshooting list (bannered to the top of the forum).
All applications output audio on the audio device selected in Windows. If FxSound is the default audio device, then browser and Discord output audio through it and FxSound in turn outputs audio on the selected physical device. Since Discord has an option to select audio device in settings you can select a different output device to avoid browser audio and Discord audio to go through the browser. Since browsers don’t have the option to select the audio output device, browser output will always be through the default audio device.
